Komatsu D57S-1 Head gasket seep
Well in that engine--anything with a shaft-or gear train.
Simon C
Heavy Equipment Mechanic
That washer is most likely coming from gear train as a thrust washer as was previously said. or could be from an accessory drive off the gear train. I have done too many D155 Engines and they have several in the gear train. Only logical place to find in my opinion.
Simon C
Cliffy
Qld
When you first posted about the head gasket and was selling it, i was going to suggest chemiweld or liquid head gasket sealer, pull the head bolts down half a turn and send it to the auction. Bit late now
Shimmy1
North Dakota
I have what you might call " a fire in my belly to do it.
Whatever you do, please don't let this project turn onto 60 pages of belligerence. I'm as stubborn as anyone you'll ever find, but when TC gives warning, I do tend to listen with intent. Good luck in this endeavor.
Shimmy1
North Dakota
Don't waste any coins on this engine until you have properly assessed all the parts, I have already brought to the front that the Fan Club for these motors in the U.K. has no members, you are being a brave boy tackling the nasty things.
For posterity. :cool:
James Sorochan
Lethbridge county, Alberta, Canada
x-water & sewer construction Now farmer.
The end play and back lash fall into spec on the gear train. I'm going to drop off the head tomorrow to make it new again and injection pump and nozzles to injection shop to do the same. I'm also going to check out a 2000 lb engine stand while I'm in town to see if will work for me. Wish I has Truck Shop's stand right about now.
chidog
kent, wa
Hmm cracked pistons? I have reused them many times in D342 engines, never had a problem years down the road so to say. But then I don't remember them looking that bad.
James Sorochan
I put the motor on a stand but the flywheel which includes the damper is to heavy making it impossible to flip over. I can’t seem to get it off. I undid the bolts on the spacer ( part 18 ) which includes the damper and tapped it with a hammer but it won’t break loose. Is it possible it’s just rusted itself onto the flywheel? Am I missing something here? Maybe it needs to be heated up with a rose bud a bit? Thanks all.
Interesting--I wouldn't heat it, not familiar with that piece, although the exploded view
looks simple. Might have to remove outer bolts with lock tabs, it looks as though there
are fasteners from the other direction on the back side. If my eyes are not deceiving me.
James Sorochan
Got it off. Once the bolts from the damper were off was able to pry it off then exposed the 6 bolts holding the flywheel on. My $200.00 engine stand has a lot to be desired. Have to use the lift in conjunction to be safe.
