Coytee
In a prior thread, I mentioned the need to remove the hydraulic tank covers however, at the time, I didn't realize they were tank covers, I thought they were access holes to the hydraulic pump! Thankfully, I only cracked the bolts loose and tightened it up when I saw oil starting to weep out!!!
On the schematic is part#15, number 32/901300. I called the dealer to get the main strainer, gaskets (of which are no longer available) and this part.
Then, they informed me the cost of this strainer is $432 and I about fell out of my chair so, I cancelled that part of the order.
It was a knee jerk reaction..... but I DO want to replace it. I've had this machine for 20 years and never knew it existed so it's probably due. (ya think?!)
Can I pull it out and clean it sufficiently?
Are (what appear to be) off brands going to work sufficiently or are they going to be made in china, get wet and get sucked into the system?!!!
VERY hard for me to justify $432 for a filter but then.... just as hard to pay several times that for a new pump.
What are acceptable alternatives, if any?
