A few projects I have done recently
IIRC we were quoted $3700 a year which is reasonable and comes with all the updates as they come out.
LOL - You may be getting all the hard stuff because you can do it.
Talked to the SteelWrist guys at Conexpo and was impressed with the quality of the unit. They were a little salty on the price for one for our 305E.
I'm not sold on those yet. They are building a new school nearby and they had a steelwrist JD50 in their lineup. It does a lot of "dust control"
I love commercial work. Sometimes it makes no sense at all but the money is good.
At the lab project -
So we removed the trees and other site improvements, undercut the building area 2' per geo report, proof rolled it which passed then filled up to subgrade with structural fill. All observed and inspected by the dirt doc.
Concrete crew comes in and starts digging footings only to find topsoil, roots and other not so good for a new building stuff under the footings 5-6' below subgrade.
Can almost see the 2-3' of red structural fill we hauled in and compacted on the center section of dirt left standing.
Structural plans called for the BOF (bottom of footing) to be 6'8" BFF (below finish floor) in the main building area and 8'-8" in the loading dock area that basically hangs off the edge of the slope.
After some engineering deliberation the dirt docs came up with a plan to excavate 3/4 of the building pad 4' below BOF and fill back with structural fill. So we got paid to haul in structural fill, place and compact and now we are being pad to cut it all out, haul it back to the pit and bring in new fill.
Called the guy that owns the pit and is also a friend of mine and asked - "You wanna get paid to take the dirt back you sold to us last week?". :D
We mob'd the 321 back in since there is a nasty tree that put the first scratch on the 325 when it left.
Had to go down another 3' in the loading dock area for a total of 11' BBF due to topsoil, roots and loose soil under the footing.
When they built the building they just pushed everything left over into this area as it was just landscape and not structural. The black seam is a thin bed of coal.
The dirt we hauled out was a nice sandy topsoil. My friend who has the dirt pit took it all and plans on re-selling to homeowners as the material is excellent "yard" dirt. I hauled 3 loads in our dump trailer to my house to fill in a low area.
Filling it back in. The fill we are bringing in is some of the best dirt we have in the area and is quite the joy to work with.
2' or so of fill placed, compacted and tested. Had to use a 279D and a trench roller to place and compact the fill due to space constraints and the lab didn't want a large vibratory roller that close to the building. They were worried it would vibrate their machines inside.
Slow going but it went in without a hitch.
Brought the structural fill out as far as we could.
Nuke testing. Not our total station, it's the concrete guys. Since the GC could not get us valid control points we didn't use our model so they threw in a few points for the UC.
Even with a nuke gauge it's always good practice to proof roll it with a loaded truck. Loaded tri-axle pushing around 85,000 lbs. It doesn't lie.
63 caveman
western Pa.
Every Goe report I have ever read (that cost a good bit of money) ends the same way."This Report does not guarantee the actual soils condition and is not responsible for any discrepancies"
Often the report will show problems with the sight and I have to wonder if the PE even bothered to look at it?
oarwhat
buffalo,n.y.
We had this happen twice. First time all the footings and piers were installed. Then they decide the entire building needs 4' of fill removed. Got paid but a real pain in the butt.
Second one the Geo report shows no problems. We strip the building area . We then find black dirt under the top layer of fill. I say it's topsoil and not noted on report. GC wants us to remove and replace at our expense. WE say no way not on report. Dirt guy comes out and takes a look. He says it's ok to build on it . I think he approved it to save him the expense of removal. Sure seemed like topsoil to me.
It's as if the engineer types have never done anything in their life, ever.
What about a design that simply states:
Remove native material 2' below footings and 2' below the rest of the site.
Import structural fill.
Order of operation:
Make the first cut to 2' minus.
Lay out the footings.
Overex 2' deep and at least 18" wide for formwork.
This makes the fill stack oversized too for the footings.
"It's a thing of beauty, Billy"
That is what common sense would dictate, and pretty much where you are arriving at after a bunch of spinning wheels and wasted time. Sheesh!
Stopped by the local Cat house and found one of the new Cat CTL's.
Good to see that Cat has added dust shields and another grease fitting to the rear UC oscillating pin. We cut some 4" steel pipe and welded our own shields on our 279's as we couldn't keep grease in the pin.
I really like the extra grease fitting and the new tie down bracket.
304 with hydraulic coupler. Our 305E has a manual pin grabber which isn't a total PITA but it can be if you're swapping between bucket and hammer a couple of times a day.
Hard to see from the pic but it's in there - somewhere.
Shimmy1
North Dakota
What in the actual frick. Sorry to be a nitpicker, but as a guy that has had to clean undercarriages for going on 35 years, that fitting is in about as stupid of a place as the grease fitting to lube the ends of the hard bar on smaller, older Case dozers like my 1150G. Why in the hell do I want to be trying to chop around that thing with a shovel? Sorry, not sorry. Just plain stupid IMO.IMG_6564~2.jpeg
What in the actual frick. Sorry to be a nitpicker, but as a guy that has had to clean undercarriages for going on 35 years, that fitting is in about as stupid of a place as the grease fitting to lube the ends of the hard bar on smaller, older Case dozers like my 1150G. Why in the hell do I want to be trying to chop around that thing with a shovel? Sorry, not sorry. Just plain stupid IMO.View attachment 311118
Well we've ran 279D's for 8 years now and very little if anything builds up in that area of the UC on what we normally run in. Mud will get caked behind the sprocket from time to time and the best way to get it out is a pressure washer. We hardly ever have to shovel out the UC on the CTL's.
Although we haven't had any issues with ours I like the addition of the fitting to help push grease around the pin. The dust shields should have been standard on Cat's CTL's from the get go.
Shimmy1
North Dakota
Obviously you never move one in the mud lol.
From time to time..:cool:
They shake themselves so much the mud doesn't stay in that location very long at least in our working conditions.
If the machine is buried up in mud it's too wet to work on the majority of our jobs in the first place. 9 times out of 10 trying to work when it's too wet just causes more work to restore than just letting it dry.
YMMV.
Back at the lab project installing the roof leaders. We supplied the 8" PVC sleeves and the concrete guys installed them in the forms. Glued a 6" coupling on the end of the stub going through the wall since the outside forms still needed to be left in place until the slab is poured. The slab is an integral part of the structure since it pours into the wall reinforcement locking the main slab into the outside retainer walls.
6" SCH 40 PVC. No comment on the safety aspect.
Roof leader by the chillers.
Again no comment on the safety or lack there of. The trusty hammer that slides around in the back of my truck came into play once again as 6" PVC in confined spaces needs persuasion sometimes to fit together.
Started a new job in North AL in John G's neck of the woods. A commercial subdivision that includes a new national chain tire store, small strip center and a parcel TBT. Our scope is the access road, decel lane and some DOT work in median.
Sanitary sewer was installed by another contractor prior to us arriving onsite. Crew cut out the topsoil and brought the rear portion of the road to grade.
Right portion of the road failed the proof roll due to fat clays that plague the site in various areas. Geotech required a 1' undercut, woven geotextile fabric, 1' of #24's choked down with #57's.
Fabric down, #24's and choking the 24's down with #57's.
Placing on site cut. This material is a sandy lean clay with 19.3% optimum moisture which is on the high side of moisture for most soils we deal with.
