It's not a jeep.
Where can I get one of those!
I wasn't actually serious... But it is interesting some of the things they have listed on thereSearch Results
www.govplanet.com
They have auctions all the time just have to search when they have on up on the block.
Found this
May be too new a series for what you have but generally are all similar
Will most likely be a Torrington Style Thrust bearing inside the bearing head, these are NOT Ball Joints. Grease worms eat these up.
The kit part number is: 2606229C92
It comes with new connector bodies and terminals and shrink tube. I only ever replaced the thermistors and reused the old connectors with a 100% success rate.
It takes 36 ounces. or 2.25 Lb's. If you climb up on the right front tire and look down inside the HVAC air intake you should see a cabin air filter. I would replace it if it looks dirty.
