Zx130-5
mg2361
Pennsylvania
Equipment Mechanic
If you look down at your gearbox you should see a pipe that protrudes at the bottom which I believe is on the engine side of the gearbox. The end of that pipe turns down into a hole which you drain from underneath. The hole underneath is just in front of the access hole for the engine just about up against the swing bearing.
tool_king
new jersey
road mechanic owner
Yes the pipe is towards the engine side with elbow on it.
