ZF Transmission Stuck In Drive
631G
Georgia
Civil Superintendent
I have a Bell 30B haul truck whos transmission will not shift out of drive. Beyond the shift issue the transmission was performing well. The transmission is a ZF6WG200 Assembly #: Z4644023196. Could this just be the solenoid or the valve bank?
Vetech63
Oklahoma
There is usually a LED screen that will run up a fault code for transmission issues on most ZF transmissions I've seen. If not, there should be some type of fault indicator like a flashing light or exclamation point or something. I have seen some machines that you have to scroll thru the monitor to get there.
Bigbert
Germany
Consulting Engineer
This is a schematic of a 6WG200 w/o any TCU (EST2 or 17 or 25) apart from E-Module for Lock-up Valve (small black plastic box).
The shifter is feeding directly 5 solenoids.
  • Electric6WG200.pdf
631G
Georgia
I’ve got a new mechanic starting next week. I’ll pass this along and keep everyone up to speed on progress. Thanks for the input thus far.
