Boyd Roper
We are using ZF Transmission Model 16 TX 2441 TO for our heavy duty off-road vehicle, which we are having issue with Error Code Z0332. We are search for ZF Transmission consultant, whom can perhaps provide their service to correct this problem. The vehicle is in Japan, and I am working to help on this matter from Los Angeles, CA office.
Any advice will be greatly appreciated, or I would like to start a dialog on how to approach fixing this issue on our ZF Transmission. This Error Code happened, when we needed to change the Differential Carrier Ratio, which was changed from 4,875 to 6,833. The Error Code shows up when when we initially turn on the engine, but will disappear when running, but will turn on again when engine is turned-off and restarted again later.
