ZF trans in moxy mt30
red-diesel
wales
Hi I wonder if anyone has information at all on this transmission
thanks in advance red diesel
Bigbert
Germany
Consulting Engineer
Hi red-diesel,
guess it is a ZF 6 WG 200 tranny.
What info do you need? Could possibly share via email.
red-diesel
wales
yes it is a zf 6 wg 200 tranny lost drive while going forword atempts to go back in reverse but not much
the oil is clean and no bad smell I checked the 5 solenoid sequence in all gears they check out ok
Not sure where to go from here.Oh I checked what clutch pipes were kicking when selecting gears
In 1st gear kv and 1v and kr were kicking. I'm sure only 2 pipes should be kicking in each gear
hope you can throw some light on the job
Bigbert
Germany
Consulting Engineer
you are fully right, only 2 hoses need pressure for drive.
Clean oil sounds promising.
Guess, the issue is either wiring or gasket in control valve. Did you check pressures at pressure ports? Need around 16 bar.
Could share an operators manual via email.
red-diesel
wales
thanks Ravensburg Will not be going back to the moxy till friday or it could be tuesday it's bank on monday
will let you know how I got on. Did not check pressures. That will be my first job I'll check converter out
as well. Did you ever see the gasket blowing in the control valve? Many thanks red diesel
Bigbert
Germany
Consulting Engineer
Hi red diesel,
let us check the pressures before stripping control valve.
KV and splitter clutch K4 driving forward, KR for reverse.
Will it move in reverse gear? Only pressure in KR and K1 or K2 or K3 dependent on switch position.
Are solenoids fed directly from gear switch? Or via electronic Box EST 2 or 25?
Parts list number of transmission would help.
4644 026 xxx?
Gaskets might do strange things or some debris in control valve might lead to stickig spool.
red-diesel
wales
Hi Bigbert,
Solenoids are fed via electronic box EST 25.
Will do all test and get back to you with transmission number and pressures.
Many thanks.
Bigbert
Germany
Consulting Engineer
Hi red diesel,
With TCU EST 25 we can exclude electrical issue. It would detect and drop to neutral.
Good luck.
red-diesel
wales
if I need to take the valve block out for checking will I have to remove the near side wheel { moxy mt 30]
thanks in advance
red-diesel
wales
all pressures ok. serial no 4644 424 1416. Checked the filter and opened the pleats lot of metal bits there looks
like bearing, So I will take the box out. Is it a difficult box to strip down and rebuild red diesel
Bigbert
Germany
Consulting Engineer
Hi Red Diesel,
you'd need some patience and skill to rebuild.
Hope, I'm able to find a workshop manual for this box when I'm back home on weekend.
Please get me an email address to share.
Regards
Bigbert
