Zerks Won't Take Grease
Discussion in 'Dozers' started by JS300, Feb 13, 2016.
  1. hosspuller
    hosspuller Senior Member
    Aug 28, 2014
    803
    North Carolina
    If you're lucky, and the grease fitting can be positioned vertical or close... take the fitting off, clean out any grease and fill with oil. Replace the zerk and pump in grease. Even a little bit of oil will loosen hardened grease.
    Warning... when using heat. Take the fitting off before heating. The heat will expand the grease building pressure against the zerk. Getting splattered with hot grease when the zerk lets go is no fun :eek:
    mg2361 likes this.
  2. fast_st
    fast_st Senior Member
    Dec 1, 2010
    1,138
    IT systems admin
    Mass
    Also the heat will anneal the little spring that holds the check ball and then you'll have an open grease fitting.
