Your opinion, will it be useful
Discussion in 'Forklifts/Telehandlers' started by TVA, Feb 5, 2019.
  1. TVA
    TVA Senior Member
    May 14, 2018
    1,731
    USA
  2. icestationzebra
    icestationzebra Senior Member
    Jun 21, 2009
    320
    Obviously would have to be a 3/4" coil with no protrusions to allow that to work. Many of the ones I've worked with the connection was molded into the side so this wouldn't work. What I had was a 2-pin deutch plug that I could power with a small battery. ISZ
  3. wornout wrench
    wornout wrench Senior Member
    Feb 17, 2012
    730
    Retired Heavy Duty Mechanic
    Campbell River, BC, The Left Coast of Canada
    If I was still working, I would get one. Lots of the old logging machines run solenoids that would fit on, would be a huge time saver.
    Not sure what it was called but it was about the size of a pen and it would glow if there was power going to the coil. that thing was handy. I have one for checking AC power, make sure the circuit is dead before I open things up.
  4. TVA
    TVA Senior Member
    May 14, 2018
    1,731
    USA
    You can actually remove the coil and slip this on valves core - that’s what it for, to keep valve open even when there no power to evacuate the refrigerant.
  5. TVA
    TVA Senior Member
    May 14, 2018
    1,731
    USA
    Just click on the link to watch it on YouTube
  6. TVA
    TVA Senior Member
    May 14, 2018
    1,731
    USA
    Probably non contact voltage indicator.
    This one actually you slide over valve core instead of coil to open or close valve, if for some reason you can’t use coil or not sure that coil works.
    That’s a permanent magnet.
  7. wornout wrench
    Feb 17, 2012
    730
    Non-contact, that is the name, thank you.
    I figured out how the one you have on the youtube worked just looking at it.
    I have had weak coils, bad coils, the orifices in the solenoids were plugged. The list goes on. Throw that magnet on the solenoid should open. Sweet.
