Yet another L120 transmission problem
KRRZ350
Spring Hill
Im new and i dont know what to do!!!
But seriously, ive been blessed with a volvo l120 around a 2004ish. Everything has been bypassed including all dash functions even the start and shut off function. The unit was working great until one day it just rolled to a stop and wont move. I pulled the trans solenoid cover and found the harness baked along with 2 solenoids. I repaired the harness along with replacing the 2 valves. I have 24v going to the requested gear solenoid along with a good ground but still the unit will not budge. The trans control box has good power and the relay has been swapped. My next step is to check the brake switch and or the parking switch. Fluid is reasonably clean. Ive heard the pick up screens are a usual culprit. Is there anything else to look into? Can i check trans fluid pressure easily? My biggest problem is the loader is a little over an hour away and in the middle of millings. Thanks to all.
