Well, what I have to add is this. First, all snap binders are supposed to be secured, wire, rope, zip tie, bungee cord, something. I got that ticket on my last trip through the inspection station. I had missed securing one handle.
As far as cross chain or not, there are many variables, and I believe no hard rule. I do on some, not on others. Depends on where there is to hook, and the angle of the pull.
That brings up what to me is one of the most important but least talked about parts of this. Pay attention to the direction the load is being secured from moving in, and then have the chain as directly in line with it as possible. Just like in rigging, the angle of the pull affects the strength. Take a 2 way choker and look at the difference in capacity between a straight pull, a 60 deg pull, and a 45 deg pull. The more angled the securement is from the force applied, the less force it takes to break.
In the example above with the lift with the rail, the rear chains are looking good to me. A balance of strenght both side to side, and mostly in line with restraining forward movement. The front chains are OK side to side, but the angle resisting rearward movement is almost straight up and down. It would not take much force rearward on the machine to break those compared to the chains on the rear. With that said, you are much less likely to have a load roll to the rear than for one to try rolling forward, such as under hard braking.
Some machines do not give much choice, so then I use a bigger chain, or a basket arrangement, as in the first set of pictures.
That brings up my disagreement with the derating of the chain due to 2 attachment points. WTF???
Each point should hold what it is rated for, so starting and ending in 2 places should double capacity in theory. Like Muzy says, double is not real, but 1/2 again works. This way each leg of the chain shares the load, and each tie down point shares the load as well.
One more thing Tiny
If you lined up 5 truck drivers, I am pretty sure you would get 10 or more ways to do it, as most of them will not be cosistent from one answer to the next.
Good topic, and hopefully lots of people pay attention. I hate dodging loose loads as they roll of onto the road.
Now, if you want a hauling challenge, try tying down a 988 loader with no park brake for a trip out of the local mountains with grades up to 23%. Make sure you pack some extra chains for that day.
