Thank you for visiting HeavyEquipmentForums.com! Our objective is to provide industry professionals a place to gather to exchange questions, answers and ideas. We welcome you to register using the "Register" icon at the top of the page.
We'd appreciate any help you can offer in spreading the word of our new site. The more members that join, the bigger resource for all to enjoy.
Thank you!
My Takeuchi calls for sae90. I change the final drive oil frequently but it always comes out gray and dirty and glitter.
Is there anything bad with using say Lucas 85w140? I don't use the machine in the winter.
Lower viscosity oils tend to circulate better. Komatsu and some Cat use SAE 30 in their finals. Perhaps next drain, pull the cover for a more complete drain, then you could also get a view of what you have going on in there.
If the original spec calls for an EP SAE 90 oil, try some oil that meets Cat TO-4 spec SAE 50.
And not, it's not thinner. Gear oils and engine oils are measured on two different viscosity scales.
If the machine works regularly in mud or water oil change periods for final drives should be far less than whatever the OEM manual calls for. Remember it's only a starting point.
2006 Takeuchi tl140. Maybe 1000 hours. I use it for pushing dirt....backfill and grade.
I've used mobil 75w-90 in past but when you shake the bottle, it sounds like water. I'm not sure a synthetic is best option.
My TL150s are nearing 10k hrs. Run 90w generic oil in all the finals. Never an issue with them.
Heck, I have 9 Takeuchis and that's all I run in the finals. Had to put duocone seals in the drives on s TB180FR once, but that's it.
Funny thing though...7 out of 10 times, one final drains darker oil than its twin. Go figure.
