Working on a hill
Discussion in 'Compact Excavators' started by thebig450es, Dec 31, 2009.
  1. thebig450es
    thebig450es Well-Known Member
    Sep 25, 2009
    199
    pittsburgh
    Who has some pics of them working on a hill? Any tips? What would be the narrowest ramp you would make put climb the hill? Thanks
  2. heavylift
    heavylift Senior Member
    Sep 5, 2009
    1,046
    KS
    is this what you are asking about....The top one you dig the red on the left and throw to the right .... to make bench to set on.... the blue is what you dig for a pipe... and usually use a dump truck to load out . or a loader..
    Is this the house project?
    either way you can work your self to the end making the bench... then if needed, dig the blue on the way out... throwing the spoil behind you... removing with a loader or dump truck
    hope this gives you an idea
  3. heavylift
    Sep 5, 2009
    1,046
    KS
    My concept of project drawing:) the red is the gabions.... Not to scale LOL
    If not the house project I at least had fun coloring
  4. thebig450es
    Sep 25, 2009
    199
    pittsburgh
    yes it will be used there. I like your drawings. What angles can these machines handle? I don't know if it would be better to clear a path and go straight up the hill or make a horizontal ramp up the hill
  5. heavylift
    Sep 5, 2009
    1,046
    KS
    they would set one the above angles .... probably with a bit of pucker factor. you can always turn the blade downhill .. and use it to hold and level the machine..
    i would guess 4 to 1 slope would be the easiest.... and could possibily level the machine with the blade.
    going straight up a 2 to 1 would work... but you may fill tippy.... keep the blade in the back to level and hold the hoe..
    I would work the top drain first.... rough it in throwing the spoil to the top as a dam to divert future rain away from the project.
    Or the top could be built with a track skid steer
    that red gabion pic should be a rectangle
  6. Scuba_Si
    Scuba_Si Active Member
    Oct 5, 2010
    36
    Manado, Indonesia
    Hi All,
    I would like to know what people's opinions are on getting a mini to go up hills. i have experience with skid steers going up and down into the back of pickups backwards, but i figure for a mini-ex you'd want the hoe out front to dig, which would leave you puckering as the counter weight at the back jiggles around as you dig.
    I have about 3 hectares of rainforest behind our resort that i'm wanting to add access paths and drainage to, once i get above my limit i'll add a new thread with pics :)
  7. Jared F
    Jared F Member
    Oct 18, 2010
    10
    Sonora, CA
    What slope?
    Here are some pix of my ex. and brush hound attachment. The hill is MUCH steeper than it looks, the only way i could work it was to drop off the top and work my way down as going back up was impossible. I almost flipped her a few times too. Got to be sooo careful.
  8. strott
    strott Senior Member
    Jan 10, 2009
    425
    Mini Excavator and dumper operator
    Swindon, United Kingdom
    If the job looks good and you finished in one piece then what more can you ask for?
    Well done.
  9. Deeretime
    Deeretime Senior Member
    Sep 12, 2009
    344
    superintendent
    High River Alberta
    I sat about 3ft away from the edge of that pile when it was cut at a 1-1 slope and still loaded trucks. It depends if u are sitting on lose material or sitting on hard packed clay, in ideal conditions when on a slope cut out half and fill the other with about 3ft all the way around the machine when u sit on your bench and u should have no problems
  10. J Olender
    J Olender Well-Known Member
    Apr 21, 2010
    72
    Northern Ca
    I do 90% of my slope work with my 310E backhoe. With practice you just get used to being on slopes. Don't swing the hoe up hill and just feel when it's getting tippsy. That's a good way to get a feel for your machine. I hope the pics came through.
  11. jughead
    jughead Senior Member
    Nov 1, 2007
    284
    retired
    soddy-daisy tn.
    pics like these are what makes this old man know he would never make an operator. even when 16 and 10 ft tall and thought he was bullet proof.
