That is 1 big shop!Well got my reversible plow on still have to put some rubber belting on the front we got a clipper storm coming this weekend 2 to 4 inches and wind so probably get to try out the new plow will report back on my thoughts View attachment 278652View attachment 278653View attachment 278654
It’s a 40X60 shop Township built it 3 years ago it’s a very nice to have everything inside and a heated place to do maintenance in.That is 1 big shop!
A Grader is 30-ish feet long. I've not measured our shop, but am guessing it's 30x50. Houses the V Plow, a hydraulic angle front blade, a wing, the grader and a fuel barrel. I like his size much better!!! Plus his is heated. Ours is a pole barn with electricity and concrete floor.It looks a lot bigger than 40x60.
Tried out pulling some ice teeth with the truck to groove ahead of the sander worked quite well I will add another 3 feet of teeth next time
Yeah, that's our problem, our private utility power company has been pocketing the money and not cutting back the tree's, any amount of wind the tree's take the power out every time, before the utility went private the province alway's had the tree's cut back and sprayed, never had very many outages in those day's.Our Power Co-op was originally set up with loop service. If your powerline ran North/South past your property it could be disconnected from one of those directions and you still had power. Over the years things deteriorated. And the Co-op got lazy about clearing brush. Took a few decades, but finally the trees got big enough to be hanging over the lines. Everywhere. 30 years ago we went thru a lot of blackouts. The Co-op gave up on the loop service wherever they could. And they started working hard on the brush/trees. I can't recall any lines in my area that have tree limbs hanging over the lines. Now they spray the small brush every 3-4 years. We just don't have outages anymore.
We call them stingers here, I run them year round on my grader, in the winter for ice blading I always take every second one out, it breaks ice better and your machine pushes easier through the ice, makes deep grooves in the harder ice.Tried out pulling some ice teeth with the truck to groove ahead of the sander worked quite well I will add another 3 feet of teeth next time
We have had so much ice this year the cloride roads are the worst they melt the snow a little and form a very hard clear ice at the bottom it usually works to keep a little more snow pack on so they are white instead of clear and shiny but all the rain changes that
Usually run the teeth on graders this was a bit of experiment to use them on the underbody
2 of the graders carry another moldboard on the ripper with teeth so we can chip and plow at the same time or go over a intersection a few times with out having to change blades
The power COOP here is similar when I was a kid Dad did a lot of tree cutting away from the lines now they have the entire right of way cleared and power is very reliable it was out for about 6 hours in a snow ice storm this year thats the longest in probably 10-15 years we had fuel in the pickup transfer tanks so we were able to keep plowing and not start a generator
For years, tree maintenance occurred when a tree was on a line. Our semi-rural area had very frequent power outages after any windy spell. Ten years ago, we had a massive ice storm right before Christmas followed by a week of near zero temperatures. You couldn't drive a mile without seeing a line torn down. Something like 100,000 people were affected by the outage and it took almost two weeks to get cleared up and and power restored. Personal generators became scarce to buy anywhere within a couple hours of here. The public outcry was loud enough and reached far enough that the power companies actively started clearing right of ways of any brushy vegetation. Today, they're staying on top of it and power outages have become almost non-existent. I have a portable generator that I maintain for backup, but haven't needed in 2 years now.
As for roads, we were completely thawed and raining a week ago. We've received 6-8" of snow this week which means lots of ice on all roadways and soft ground under a thick blanket of snow. Don't pull your truck off the gravel because it'll be stuck in a mire of muck if you do.
