I was going to guess a full day to set up a rig like that,with a crew of 8 to 12 workmen,&other support unit's.I wounder what propeller weigh's.Truly impressive.
Of the top of my head ..i think the hub weights about 24,000 lbs ..each feather about 6000 lbs.... when possiable the whole thing is put up hub and blades one shot..
They had to move the crane to set the hub? a mistake they wont make again...I remember hitting this wall on a wind farm ..the pads were made a little wider and the tower was laid out side by side ..base,mid, top ,using a 80 to 100t tail crane to stand them ....
the hubs were laid out to allow one blade to come back behind the tower ,, the erection crane was essentially placed in the "V" of the hub and feathers ..by doing this we were able to get the hub's 35-45 feet closer or as required by the crane..
something thats a little wacky about those mills ..that not alot of people looking in realise ...if you install the top section of tower ...you have to get the Nacel on ..you cant leave it..the tube is only truly ridgid wihen the Nacel is on and its weight apllied to the tower ... Ive seen our equipment stand for hour's waiting to get the wind right for the Nacel while holding onto or hooked up to the top section ...no sense putting it up if it has to come back down ..
the tops can weigh around 50-60,000 lb's the Nacel weight's can vary ..100-130,000 lbs..depending...
