Mikefromcny
I'm looking at an 01 883 bobcat tomorrow morning. 2900 hours, runs and drives good. Hydraulics seem to work fine and are strong. it has a bobtach that is not working. Guy thinks its the switch but I've also read a failing hydraulic pump will get the spool contaminated to the point where it binds. Anything I should check on this to make sure I'm not buying something with a failing pump? Thank you.
