Willie B
"...converter only in 1st and 2nd, and would run in 3C then shift to 3L and then 4L."
short answer, yes. However, the trimmer valves for shift points can be adjusted by trial and error but require removing the oil pan each time you do it so it can be a time-consuming and frustrating job. The best way is to remove the valve body and take it with the little oil-supply tubes to an allison repair shop that has the calibration test bench which they then attach it to and then do all the calibration adjustments. If the engine feels doggy, maybe the shift points are slightly on the low side maybe caused by the valves springs becoming a bit lazy over 40 years. I'm not sure what a shop would charge for a recalibration. Its been 30 years since i had the last one done
There is a limited amount of information still available for this transmission. What I have found suggests torque converter is variable in 1 & 2, 3 & 4 clunk in. I sense no torque converter action in 3&4.
