Will I have enough pressure to run the Auger hooking into the thumb fittings?
Discussion in 'Compact Equipment Attachments' started by Danny Steel, Jun 12, 2012.
  1. Danny Steel
    Danny Steel Well-Known Member
    Jun 12, 2010
    187
    Farmer/Landscaper/Welder/Fitter
    NW Ontario
    When I made the thumb for my KX-71 I had the Kubota boys adjust the pressure for the thumb.
    Now I'm planing to use my auger that I currently use on my skid steer work on my Mini- X as well.
    The big question......will I have enough pressure to use a 24" auger?
    I don't know what they set the pressure at:beatsme......but they gave me more on the bucket and the stick at the same time
  2. Haddy
    Haddy Well-Known Member
    May 6, 2011
    146
    earthmoving contractor
    Atiamuri New Zealand
    I would have thought you will be right . Might be a little slower
  3. CM1995
    CM1995 Super Moderator
    9,046
    I have a Bobcat 334 with hyd thumb that I use an auger on from time to time. The auger runs off the thumbs hyd's, I have to disconnect the thumb and hook up the auger. I haven't had a problem with pressure or flow but the biggest auger I ran on it was a 12".
  4. Hendrik
    Hendrik Senior Member
    Mar 6, 2009
    1,232
    Adelaide South Australia
    I am no expert but I believe that they not so much alter the pressure but rather adjust the relief valve to be at ~70% of the bucket relief valve.
    My KX41-3v can run a 24" auger but does not have the same power as the dingo, the 41 has 17hp and the dingo has 25hp. Most times I will drill a pilot hole with a smaller auger before using the 24".
    Your 71 should play with a 24" but may well stop when encountering a rock or large root, as it should.
  5. Danny Steel
    Jun 12, 2010
    187
    NW Ontario
    I forgot about the relief valve. I think your right, and I'm about to find out soon.
    Thanks
