Well guys this is the next chapter of the history of the tipping RT62S:
It seems originally it had no "tail" but just a straight end, the seller semingly modified the crane in order to make it look more recent as all modern GROVE cranes have one.
This crane as they say in the Grove history pages was the first one with a revolving cabin, and to me it seems that they did not got their numbers right and had a front (boom side) heavy crane when fitted with the 80 ft option.
I had to make my unit safe so I have fitted back the dummy tail but filled up with steel plates cut to size and sandwiched in to a gross weight of 7700# but also added an extension to the structure of 12" to the rear so now the weight sits not only 3.5 MT more heavy but has increased its gravity center from 7 to 8 ft from pivot point, that increases leverage by 14% and the weicht is almost doubled, so teeting was done in this way:
1.- Steel frame dimensions entered to a Steel Analysis Tension/Stress/Moment calculator and it passed with no problem (oversizing parts in those years was usual)
2.- The crane was raised on the outriggers and located in a truck weighing unit which entered us the following results:
Boom horizontal fully retracted for all initial tests: Boom forward 75,000# 50.6% load front outriggers, 49.4% back ones
Boom backwards 75,000# 48.8% front outriggers, 51.2% back outriggers; Boom to the left or right 75,000# 1.17% (880 lbs) more heavy to the side that the boom is pointing, give or take 100-120# that seem to be the weight difference because of diesel and hidraulic fluids difference in weight, so in horizontal position we had an almost ideally balanced crane without load.
3.- Tests on weights raised at 45° an fully extended all booms, raised a 5500# weight, from the ground and turned the crane full 360° at about 2 ft from the ground no intention of tipping at all, we are going to do the same over the weight recorders and see how the actual weight loads shift from one outrigger to the others as circling progresses, that is still pending.
So thanks to all of you that gave their advise on different aspects of this work with out it we would have had a harder and longer time to sort this out.
Regards to all of you
