Why I hate boom trucks
crane operator
sw missouri
How in the Hell does one roll a Boom Truck on a FLAT road, Boom DOWN??
I'm telling you- those things are top heavy SOB's in the big ones. Looks like all air ride suspension, and it has those outriggers like a concrete pump, all above the frame rail.
I'm guessing he was hauling a$$, delivering it (WHERE'S MY NEW CRANE THAT'S 11 MONTHS LATE) and took a left off the main highway behind him, and flopped it over right into that pole.
Steer, two air lift axles, tri drive, and a rear air lift. Seven axles all together. Factory says GVWR is either 93,000 or 105,000.
155' of main boom hanging out above that cab. Got a nifty jib too. Hyd. offset to -80 degrees.
that would be a nice kit. It would be good for grain elevator work too, and setting HVAC if it was not too heavy.
Cheap "old" Geezer
With Skyking on the sheared bolts, should have been able to see there were broken ones by rust trails or loose washers, IF Ever looked close while lubing that, bad day.
As to that ALTEC, if they have to go that heavy, are really no advantage over True Crane machines, these are a nickel and dime distractor of what is really needed. I see MASSIVE Rotator Wreckers on the Highways, several companies around here have them where REQUIRE a Release of DOT Axle Load schedules as Emergency Equipment, drive like crap, cannot take anywhere Off Road as sink like lead balloons. Look Pretty but value or worthiness? Crane can accomplish as well in many instances or if Must Side load pull, just a wrecker as TS Built.
Keith Merrell
Cottonwood, AZ
Kinda off topic, but speaking of trucks and idiots, you know how Ritchie Brothers does videos of the trucks driving back and forth now? I always cringe because I keep seeing idiots revving the truck like crazy and then burning the clutch and spinning the tires. lol
Natman
ID
In my area, a BTC Manitex boom truck that was used for delivering and setting septic tanks, broke off at the turret, and fell onto the ground, pretty exciting I heard thru the grapevine!
Here is a delivery conveyor truck that had a bad day. The jobsite is Freightliner NW and there is a lot full of oddities.
Love this short stout all wheel drive high rail monster knuckle boom truck.
Cheap "old" Geezer
I find it funny, that 4x4 knuckle sitting behind a RSH and aside a RSTank!
Most of those machines likely in there for Emissions Warranty.
