John Griffin
Small cam Cummins 250 hp 685 ft lbs naturally aspirated. Not much power to move 72,000 lbs.Yours is a big cam cummins isn't it? Mine is a 6-71, it at least sounds like its going fast....
Be glad you didn't---fuel related parts have become a issue.I have a 444 cummins I was going to put in mine
Its in my back room if you can find someone that needs it. I guess maybe there's someone restoring a truck and always wanted a 444.Be glad you didn't---fuel related parts have become a issue.
Cummins made 1" 2" 3" risers that went between jacket cooler and crossover, I know where severalWhen I was looking at going to water cooled instead of air to air, I got to measuring and test fitting stuff, I really wasn't sure the crossover was going to fit, without carving around on the rocker box covers.
We do but shouldn't have to. At that point I may as well drive a manual trans.
I actually have a mack 350 sitting here. It really hadn't crossed my mind as a possibility for repowering a tms300 with a mack engine. I also have a larger 13 speed and a 350 cummins sitting in my stash. I have two tms300s but we only use one of them. They are stout cranes for their size and hold up well to tree work. I'm kinda on the fence as to what direction to go with them. Sell them and buy a newer 50 or 60 ton truck crane or sink some money and time repowering them. Neither has an LMI. I keep getting water in my forward rear axle on the tms. I need to change the oil again and try to figure out where it's getting in.I've seen one tms300 with a mack 300 in line 6 repower job, it fit really well, and the mack torque would be nice for driving. Mack at least has all the fuel and air and ps over on the passenger side, vs. cummins or cat.
I've seen several big cam's as repowers, and they are a tight fit if you have a big turbo. Fuel pump and air compressor/ ps pump are a bisterd to get at.
I have a 444 cummins I was going to put in mine, and never got around to it. A 3406 won't fit without severely cutting the frame rails up front.
My tms300 is going to become a yard crane/ counterweight loader. Going to set in one spot up on blocks where we can get the trucks and trailers right beside it. Make a stack of weights around it like playing cards.
I think if I was going to repower my tms300 today, I would find a old mechanical 4 valve mack, and crank up the pump a little, with a straight 9 or 10 speed. If you go to any bigger 13/18/15/8ll transmission, you run into length issues.
Looks like he slid quite a ways.....![]()
UPDATE: An overturned vehicle has traffic on Route 309 near the Telford exit backed up | NorthPennNow
Emergency responders are on the scene attempting to place the vehicle uprightnorthpennnow.com
But it sounds nice.Small cam Cummins 250 hp 685 ft lbs naturally aspirated. Not much power to move 72,000 lbs.
