My opinion would be the radial lift machine would be a good fit for what your doing. While it doesn't have the bigger hyd pump, if your a little more patient you can still get the work done. Be selective on the mulcher you get, if you order a 340B I would consider the Enhanced High Flow version and get the counterweight kit. I would try and find a mini ex instead of the back hoe attachment. I had one years ago and they may be better now, but it still wouldn't hold a candle to a 7500 pound or larger mini ex. Much better for clearing, digging waterlines and so forth. I would pass on the Beak for what your doing. It will be difficult to handle more than one log at a time and only having one pinch point will mean spending time positioning the attachment for the best fit. I think two independent grapples is much better for forestry work. I have this attachment
Saber Tine Heavy-Duty Tine Grapple (quickattach.com). I use it to clear timber and really like it. There are many other options, but something similar to this would be better than the Beak for what your doing. The Saber tine description says its HD and it really is. I used it last year to move 100, 80' 5000k pound electrical poles and 200 smaller poles, it would worked like a champ and there was a huge amount of stress on it moving those around. Sounds like a cool project you have planned.
