Range Shift Trans, see if that changes leakage rate.
Those are brand new, didn’t hear anything last night crawling on top of it looking for a wire short.don't forget any transmission mounted valves
Takes same time about a hour from 125 to alarm goes off when sitting still. Only leaks down when idling. Could it be cause the fan clutch is engaged all the time? That’s my thought process, sitting here idling in 20 degree temperatures and the engine gets up to 200 degrees if I let it, there is no automatic fan clutch engagement I have to manually run it which can’t do that while sleeping, so I leave it on when I sleep.Range Shift Trans, see if that changes leakage rate.
I didn't pay a second ticket to State of Michigan, they basically took the information that they were given from a different state and filed it on my Michigan driving record. Just so happens, 20mph in Michigan qualifies as reckless driving. I dunno, maybe I should have sought legal advice. In short, this was seven or 8 years ago and I just taught my self not to speed. There's a posted limit, if I obey it, I can't get a speeding ticket.
By the seat of your pants is no gauges.Speedo not required, but windshield is. Actually no instrument cluster is also fine.
Found one leak it’s in the proportioning valve under the 5th wheel, only reason heard it is some water got on it. Welp landed in Bozeman, be home tomorrow200 isn't high, but I'm surprised idling in 20* temp. That radiator is full of. hose from solenoid to hub or
hub itself could have leak.
More of a BP-R1 valve as the part number is 3081426
I think one of the magnets went, will find out in 24 hrs.Electric Brakes are temperamental but work well when working. May have developed a short that eventually opened then defeated the system and set your adventure ride in process.
