colson04
Hmm, never seen one of those before. I'll have to look them up
Napa Auto Parts has them it's where I seen it, but Amazon is cheaper. I went with the 10' chain.Hmm, never seen one of those before. I'll have to look them up
Guess I will find a way to switch the towers out then. Don't like the oddball sideways backwards as$ shifter.High tower-narrower gate and better leverage for smother shift. Very few come with a low tower anymore.
Tried that when it was still in on old transmission, going to have to press it out now I have it out. Though that's what I'm going to do along with straighten the shaft out some. Heat it up till magnet doesn't stick to it bend it as needed.If you pull the pin above the tower, I think you can just switch rods, if that's what you are trying to change.
Sounds good to me, some moron (weekend warrior city slicker) busted up the road last summer and now we are loosing our road in. So come spring I need to fix it and put back as such and build it up.A LOT!!
I have ran out of time and decided to forgo the modification so all is almost back together, one more pinion seal replaced, and put last new u joints back in. Sticking them in the freezer for few hours makes it easier pressing them in with guide bolts on each side.you may have to buy a new isolator/pin kit. i've never had any luck trying to separate them without destroying the isolator- around here, they are usually seized together
Feels like I'm going down the same rabbit hole as the last semi cause there is sure no DIP switches on it. I can call Volvo in the morning, I'm sure there is something with the 3 buttons on the cluster itself.Adjustment is only to get the sensor the correct spacing off the rotating element
Different diffs have changed drive line speed so probably shows slower than actual
Most electronic units use Dip Switches to reprogram the head for the signal
Age of machine change in ratio and lack of company OE manual makes it guesswork
May find something on the net if lucky
I don't think he has a ecm. I think his is a pt pump n14 with no ecm.Could be cal in ecm
Those buttons are the "DP" switches that Dmiller is talking about, "I think"Feels like I'm going down the same rabbit hole as the last semi cause there is sure no DIP switches on it. I can call Volvo in the morning, I'm sure there is something with the 3 buttons on the cluster itself.
