Which CTL for pool excavation.
Discussion in 'Compact Track/Multi Terrain Loaders' started by Ivan01, Aug 20, 2016.
  1. Ivan01
    Ivan01 Active Member
    Apr 18, 2016
    28
    USA
    Hey guys. I am looking for anyone's advice on a solid compact track loader to do swimming pool excavations. I have a contract to do about 250 pool excavations per year and currently have a John Deere 332e that's not standing up to the task. After about three hours of digging I can't even make it out of the ramp because how much it goes down in power.
    I am looking at purchasing a bobcat t770 brand new. But would like to know if there are any better alternatives. I'm looking for a bare bones machine with nothing fancy. One that'll just dig dig dig non stop. I would like to have a machine in the 80+hp range
    Thanks guys.
  2. Mark13
    Mark13 Well-Known Member
    Feb 28, 2013
    247
    IL
    If you want a CTL that isn't fancy but will dig with the best of them, have a look at the Takeuchi machines.
  3. lumberjack
    lumberjack Senior Member
    Dec 25, 2011
    1,046
    Columbus, MS
    Another vote for Takeuchi. I had a TL250 that we used on a large house pad in 2013. We cut and piled 2k yards, 8k fill imported, 1k of the piled cut spread and the rest loaded and spread on another lot. I'd burn 4.5-5gph pushing fill, but man it could push.
  4. JNB
    JNB Senior Member
    Feb 13, 2012
    823
    Flyin' low and rollin' slow...
    North Texas
    Back in the day we used an International 100E to dig pools...and we did a gang-load of them. The 100E weighs in at about 15k with a 4n1 bucket and is pretty narrow. Being narrow really helped in maneuverability in the tight confines of back yards and pool bottoms. I own a Kubota SVL90 and love the way it works, but I'll agree with both Mark and Lumberjack on the Takeuchi choice. The TL250/TL12 is heavier, narrower and has a nice tighter turning radius than the Kubota. My choice came down to the dealer, but if I dug a lot of pools I may have gone Tak. They are tall though, but if that's not a problem for you get a Tak with a 4n1 and go to work.
  5. CM1995
    CM1995 Super Moderator
    9,909
    If you a want a bare bones digging machine I'd look at the Tak too.
    I just purchased a new Cat 279D because I wanted frills and get all the equipment one brand. I use a CTL for utility support, backfilling and fine grading work, not heavy digging.
  6. movindirt
    movindirt Senior Member
    Sep 6, 2013
    671
    under a shady tree
    Why not a excavator?
  7. Ivan01
    Apr 18, 2016
    28
    USA
    often times the dump trucks are out in the front of the house and mobility is necessary to load the trucks with dirt.
  8. Mark13
    Feb 28, 2013
    247
    IL
    I'm not sure what your budget is, but would a CTL/SS/Mini Wheel Loader to transport the dirt and a Midi excavator to do the digging be an option? I'd think a large mini or a midi excavator digging and piling and a "skid steer" moving the dirt to the waiting trucks at the road would have to be faster then digging and transporting with a skid steer alone. Depending on the distance to the road and if you kept the 332 you could even run 2 machines transporting dirt to the trucks while an excavator was digging the pool.
  9. cdm123
    cdm123 Senior Member
    Nov 12, 2009
    270
    manitoba canada
    This is what I was thinking as well.
  10. Ivan01
    Apr 18, 2016
    28
    USA
    I don't have a budget for a mini excavator. And I would also have to hire a 2nd operator. In some cases the mini excavator would be ideal but the soils here in Houston are rock free so a skid steer will do the job just fine. Just need to find one that can stand up to the abuse day by day.
  11. movindirt
    Sep 6, 2013
    671
    under a shady tree
    Then go talk to your Takeuchi dealer, that would be the best machine for your needs it sounds like.
  12. Stick Pro
    Stick Pro Well-Known Member
    Jul 16, 2007
    154
    Fresno CA
    We use our cat 299d2 to excavate swimming pools. We dig 4 a week, any ware from hard pan all the way down to white sand. The 299 will climb out of a ramp better than the bobcat t770, I find it digs better than the bobcat also. The cat is does not beat you up as much as the Deere or the bobcat. Good luck let us know what you decide to get.
  13. Ivan01
    Apr 18, 2016
    28
    USA
    Thanks for the advice, is there any technical reason why Takeuchi would be the better choice for digging in tough clay? Over lets say a bare bones bobcat or cat?
    Thank you, I will also stop by the cat dealer and have a chat about a 299. They are pricey but if its a work horse i will consider one.
  14. skata
    skata Senior Member
    May 10, 2007
    1,030
    midwest
    takeuchis are at the top of the list when it comes to brute force in digging. bobcats tend to have weaker drive motors. cant comment on the cat.
    and the takeuchi hydraulic over hydraulic controls are very nice and easy to use.
  15. CM1995
    9,909
    Take a look at the 279, I'm impressed so far.
  16. Catbota
    Catbota Member
    Aug 1, 2016
    5
    Pa
    I have a Kubota svl90-2 and it is a great machine. I demoed a tak tl10 and the 90 side by side and the Kubota surpasses the tak. While I know that the tl12 would have been a more fair comparison, it didn't take long to long for me to decide which machine was right for me.
  17. pafarmer
    pafarmer Senior Member
    Feb 4, 2010
    883
    Land clearing, demo, site prep etc. Ex Pro Motocro
    Somewhere in the woods !
    CAT 259, 279, 289 of 299.....loads of power to haul full loads up the ramp. We use out 299XHP and there is nothing it can't power through and the ride is magnitudes of order better than the TAK...this keeps the operator working faster and fof longer periods of time. The 200XHP's are expensive but cost is relative, these machines make very short work out of a pool removal...Time is money in that game as it is in so many others.....
    Ride control of the new CAT iron is a great feature....good luck and let us know what you end up getting...lots of great equipment on the market these days...
  18. Ivan01
    Apr 18, 2016
    28
    USA
    Thanks guys, I went to CAT and liked the 289D, my only concern was that the lift height of the bucket was only 10'5", that will barely clear the top of my dump trucks and not a lot of room to shake the bucket. My John Deere 332E had a similar problem. The T770 has an 11" dump height and this works out. I really like the 289D and it was a very smooth machine and I like how its well thought out as far as ease of serviceability. Another concern I had was the power of the CAT D (269D, 279D, 289D, 299D) machines. They jump from 74hp up to 100. There is no in between. Will a 269 with 74hp perform the same as the 289. They have different ROC but will the force to excavate be much of a difference?
  19. pafarmer
    Feb 4, 2010
    883
    I own and operate three of these model CAT CTL's.., the 259D, the 289D and the 299 XHP....The difference in ROC is due mainly to the weigh of the machine itself and that is the main limiting factor. The 259 does perform every bit as good as the 289, in some case better. The same motor pavkage driving less weigh around proves to be a very good package, for me the 289 is. Big under powered due the size the weigh of the machine itself ...I can climb bigger hills fully loaded with the 259d better than the 289 D but the 289 can carry more weigh. The 299 XHP is an animal and lacks for nothing. It out performed anything on the market today in my opinion. The best thing to do would be to Demo each size on chula work conditions and pick the one that best suite those needs, I think you will find the 259 and the 279 to be all the machind you need. Make sure you get the wrigh pavkage, it will bring up the ROC numbers quite a bit....hope this help. Other son here have great advise as well across varies brands. Hopefully CM will chime bavk in ad he just bought himself a shiny new 279 and He is a wealth of experience and unbiased information....good luck..keep asking questions nd try them all B 4 U buy !
  20. Ivan01
    Apr 18, 2016
    28
    USA
    I am torn between the 299D2 and the T770. Both have been optioned to be bare bones pretty much.
    the T770 is bare bones with no options, I am being quoted $71,000 for the machine
    The CAT 299D2 I am being quoted $75,592 but it has ride control and an advance display.
    I am thinking if I can get CAT to get down to the price of the T770 I will go with the 299D2
    Any opinions on pricing?
    Thanks so much for every ones help, its really helped me narrow down on what will work best.
