Where has Nige been ?
Multiracer
Northern,Ohio
Owner/ operator
Technology vacation or a real vacation? I miss his pearls of wisdom re: heavy iron. :notworthy
I need to make something clear .......... it was a vacation so that the wife could spend time with her family. I spent a large part of the time between the beach and looking for an apartment to buy - while most of you guys were shivering in 30 below temperatures ........ it was 5PM when that photo was taken
Just to prove I actually went on a plane - taken in Panama airport just before boarding.
BillG
S. Wisconsin
Nige,
Anybody can take (or find) pictures like this. What we need to see is a picture of you in your beachwear with a couple of lovelies on each arm. Now THAT would prove your story. :D
digger242j
Southwestern PA
Self employed excavator
And let the wife see them .......... I don't think so ............
Sooo, you're saying the wife and the MIL wouldn't qualify? Better not let them see that post either... :cool2
clintm
charlotte nc
here's the JB Weld let me know if you need any more . we gotta have it on the job 1st thing in morning:thumbsup
powerjoke
Missouri
owner/operator/estimator/mechanic/grunt/ditchdigge
Yeah, the little man inside with a hammer finally got out lol
Pj
Scrub Puller
Yair . . . I think I have mentioned before that it frustrates hell out of me on modern machinery that I can't wind the bloody things over with no fuel.
If that failure is due to hydraulicing on start up it was an easily preventable disaster.
Fluid on top of a piston can get there from rain down stack (as mentioned by kshansen) a cracked head, a pin hole in liner, a stuck injector or the one that I have struck a couple of times . . . certain English engines had a cold start solenoid that admitted fuel to a vaporiser in the the inlet manifold.
If that solenoid failed it can fill the manifold with diesel and lock an engine which is okay if it locks it but on an easy starter like a Perkins or a Standard it can put a rod out through side.
Cheers.
td25c
indiana
Hope you had a great vacation Nige:) Looks like the rod journal got pretty warm in the picture. Spun bearing? :beatsme
kshansen
Central New York, USA
Any thoughts on this, other than "it's broke"....?
On second thought the rod and crank do look like they were hot. Don't tell me someone forgot to put oil back in after draining for oil change? Is that the only pair of rods that had a problem? Does not look real new an engine so I tend to rule out an assembly problem.
