Hello All,
I am looking at purchasing a 2nd hand Terex Schaeff HML32 wheeled excavator, I wish / intend to mount an Elkaer HS2300 triple blade limb saw on the end to cut / trim hedges and tree lines. I'm not an expert but from reading the specs of the excavator and also the required flow for saw head it looks like it will work? Can any one see any problems resulting from this combo? Also wish to set it up to work via an electrical on/off switch (Thinking blades should only spin one direction) and have and emergency stop button for "safety" as apposed to using the hydraulic breaker pedal (which you would have to keep your foot on to keep blades spinning but also would have capability of spinning the wrong direction). What would be involved in setting this up?
The HS2300 specs as supplied by dealer below;
Working Width 2300mm
Branch Diameter (max) 250mm (max)
Oil l/min 60 l (min) ***I assume optimum flow maybe more than this??***
Oil Pressure 210 bar (max)
Blades 3 x 800mm
Weight 220kg
I've also attached photos of the HML32's hydraulic specs and a schematic diagram (diagram is actually for a TW85, which I think is exactly the same? - just newer and being branded as Terex as apposed to Terex Schaeff)
Blades 3 x 800mm
Weight 220kg
