treemuncher
I'm currently trying to remove a patch plate installed on my Lamtrac prior to my purchase of the machine. The machine developed cracks above the lift cylinders where the machine was not designed heavy enough for the punishment it takes in. I've been plasma gouging out the perimeter welds but have at least 8 plug welds @ about 1" diameter each to deal with in order to remove this plate. Patch plate looks to be 3/16" or 1/4". White paint outlines the cracks in the patch plate. My previous crack patch next to the left cab mount (primer brown paint area) with 7018 is still holding strong after about a year of use.
I'm looking for more knowledgeable welders that have to deal with this type of stuff on a daily basis. You experience may teach me and others a better way to approach this kind of situation.
I was fortunate enough to find a large annular cutter in my milling bits that fit into my mag drill. I drilled out beyond the circumference of the plug welds with it until I was nearly through the patch plate. Chisels and a railroad pry bar got most of the plate off, leaving the plugs behind for the plasma and a grinder wheel. I'm not sure this is the fastest or easiest method but I was making progress prior to shutting down for the evening.
After I get the old patch plate off, grind out & weld the cracks, I will install a larger 1/2" thick A36 plate to stiffen the entire front structure. The cab mounts are causing the ends of the front face to droop down so I will install a plate that measures the full width of the front. I will lay it in with some Washington Alloy Superflow 71tm mig wire if it's not windy when I go to weld. Otherwise 7018 if I have to deal with windy conditions. All weld areas will be pre-heated to minimize moisture.
Remember Newton's Law of Motion #3 : Newton's Third Law of Motion states that for every action, there is an equal and opposite reaction. This machine dishes out one hell of a beating on a daily basis therefore it takes in the same amount of energy. It's amazing that it stays together as well as it does. 20",30",40" and larger trees eaten daily. Sometimes stumps too.
