u kidding?Wain Roy is what it looks like to me. My suggestion is pull it off and use it as boat anchor.
sorry maybe i did not post correctly but i mean the exhange system on the bucket or the excavator is it a quick style or what?u kidding?
is it a bad exchange system?
what would be a better option on this....when buying a bucket how to explain what couplerr i have ?The name of the coupler is called a Wain Roy. It is a quick coupler. I, perhaps inappropriately, expressed my thoughts on that particular coupler.
Using it as a boat anchor is great, I absolutely hate my WR coupler. It came on my mini, and it's up to 4300 hours and I just don't really want to dump $10-15k on a new coupler and buckets. The reason it's so bad is they never stay tight, you shim them back to tight and it's not 20-30 hours it's loose again. I personally prefer a wedge coupler over anything else, but anything is better then WR.
why 10 to 15k.....
im new in 2 this ....only had bobcat and trucks...
what would be a good manual quick coupler?
Well I have 3 buckets, a ripper, and a pusher for my mini so it's a lot of attachments to buy, and unless you can find used they aren't cheap. I like the wedge style couplers, there's quite a few makers like WBM and CWS.
But it also depends how often you'll use the machine. If it won't see a lot of use, the odd welding every once in awhile it get you by and the coupler will be ok. Also depends how often you change buckets.
Yea if you're going to change a lot it's a good idea, and won't cost as much if you have to buy attachments either way. Don't take it the wrong way, you can get by with WR, lots of guys do i've been doing it for 5 years it's just not anywhere as good as the other systems.
