What is the reason?
hvy 1ton
Lawrence, KS
Normally it's haul distance. Only time I saw one in use they were using belly dumps and moving the dirt close to a mile. Could be that self propelled scrapers aren't real popular in that region. I don't know that to be the truth, but that's the impression i get.
John C.
That thing is basically a twin engine elevating scraper.
DIYDAVE
MD
could be several reasons, speed, haul distance, price to operate that vs pans, I would say economics at the root...:beatsme:beatsme
JimBruce42
Pennsylvania
operator
Those Holland Belt Loaders can move A LOT of dirt fast. I remember reading that the one Ames had when they did a portion of the Denver Airport loaded 777 belly dumps in a minute and a half.
DPete
Central Ca.
That's pretty efficient for big yardage. like water running in a bucket. It's a modern day domoor, not a new concept. They will work their way back and forth across the cut and the cut will stay pretty smooth.
Tinkerer
usa
That was really soft soil in the first video. The ideal cut is in material that will hold a vertical 5 to 6 foot wall. That is how we used to get those high speed loads. It was nasty for the operators though when the wind was blowing very hard.
movindirt
under a shady tree
Thanks for the input guys, I hadn't ever seen one before, I figured it was a one off deal. Looks like in loose dirt or maybe sand it would work pretty good!
RZucker
Wherever I end up
Mechanic/welder
that is a great vid. Back around '97-'98 I got to work on an old HD-20, just clutch and brake adjustments. But hearing that 6-110 howl when it was working.... That was cool. It had a cable unit with an arch over the nose similar to the double 20's in this vid. Sadly when scrap was 400 bux a ton...
