What is the Difference between Gasoline 10w-40 and Diesel 10w-40, Big Screw Up
Fleming, co
I was a gallon and a half shy on my hydraulic fluid for my Mustang MTl25, so I put in some 10w-40, just like the tank says, not looking to see if it was gasoline or diesel brand. Turns out I read on the jug for gasoline engines. Should I drain my tank and replace with diesel 10w-40, or what should I do?
AllDodge
Kentucky
The gas/diesel oil difference pertains to when used in the engine not hydraulics. I don't see you have a problem
bobcan
Cold but Sunny, Western Canada
^ Agreed _ until some Petroleum Expert chimes in here, I will say that I suspect the differences are more likely for Combustion Chamber/ Cleaning purposes, not Lubricity in a Chain Drive capacity.. but that being said, a call to your local Bulk Fuel Supply service should dispel any concerns.. I should think!!
mitch504
Andrews SC
The difference is that the diesel oil has additives to neutralize the higher level of acid that diesel engines put into their engine oil. I wouldn't be the least bit concerned about some gasoline spec engine oil in a hydraulic tank.
apetad
Leander, Texas
Compact Construction Equipment Sales
Mustang approves any high quality high detergent 10w30 15w40 (depending on the ambient temperature chart) for use in the MTL hydraulic system.
apetad
Leander, Texas
Operators manual MTL16 20 25 all in one book
I appreciate every one helping me on this one.. I was dreading draining the entire system over a gallon and a half. Is that a manual I see, I wish I had one. they are very hard to find
Mustang Part number 908306 about $35 plus shipping
Amy Mustang dealership can order it for you.
You can contact us here if you would like to order one, we can drop ship anywhere in USA http://austinpowerequip.com/
