What is the best head gasket sealant?
Discussion in 'Shop Talk' started by munro45312, Oct 10, 2019.
  1. munro45312
    munro45312 New Member
    Oct 10, 2019
    1
    Memphis,TN,USA
    The best head gasket repair is.......... A new head gasket.
    Each type of head gasket is specific to the engine as it has reinforced pieces of metal at the points required. The is no paste, glue or any other magic that can stand up to the pressure for any reasonable length of time. What will happen is that when it fails it will do so spectacularly and WILL lead to a large bill to repair all the internals of the engine when the very large bang tries to fire the Pistons and other internals through the hood of your car.
    AND
    ____________________________________________________________
    Source: https://time4buying.com/best-head-gasket-sealer
  2. B0B
    B0B Active Member
    Oct 28, 2015
    34
    Mechanic
    Hawaii
    I like copper spray gasket sealer. It makes life nicer if and when you tear it down next time.
  3. willie59
    willie59 Super Moderator
    Dec 21, 2008
    12,275
    Service Manager
    Knoxville TN
    The way this post is worded it looks spammy as all get out. With an IP address in Punjab Pakistan, I call spammy.
    check, Nige, MarshallPowerGen and 3 others like this.
  4. DIYDAVE
    DIYDAVE Senior Member
    Feb 18, 2007
    1,526
    MD
    I concur. If you need HG sealant, just search for it!;)
    Anything with sodium silicate(water glass) as the active ingredient, will fix small leaks...
    The bit about engine sealing is at about the 4 minute mark, in this video...
  5. Nige
    Nige Senior Member
    12,283
    Whatever the service manual for the machine might recommend, or not, as the case may be ..........:p:p
  6. willie59
    Dec 21, 2008
    12,275
    Service Manager
    Knoxville TN
    Whatever MacGyver would use, eggs, cigarette tobacco, shredded toilet paper, anything but replacing the head gasket, right?
  7. DB2
    DB2 Senior Member
    Jan 4, 2015
    352
    Winnipeg MB Canada
    I remember an old timer using water glass to stop a leaking liner seal on an ancient Cummins
