Cat977
Finally got back to 977 switching tracks from my older 977K to the 977L. Seems I have an exhaust leak into the coolant. (I don't see any coolant in the oil). There are small bubbles coming up at idle. I let it run for 20-30 min. at a fastish idle and the temperature ran up to too hot. Worse yet it’s pushing oil out the exhaust manifold connection to the stack!! Left it overnight and added 2 cups of coolant. Idled for 5 min. then tried to push hard with it. Took about 5 min. and it's pushing coolant out of a loose cap and it's too hot! I'm looking for confirmation on it being a head gasket and I'm wondering if the oil is coming from the turbine bearing? The turbine spools right up and the engine is strong. The machine has been sitting for 5-6 years. I wore the tracks till they were running on the pins. I used to run it back and forth a couple times a year till I snitched the batteries 2 years ago.
I was referred to a local service man with a track press. That was a relief… I feel that the machine is solid and worth additional investment.
The loggers just finished taking 40 walnut trees and I would like to use the 4 in 1 bucket for cleaning up! They’re leaving the skidder for me for a bit, but I should figure out what to test before tearing into this project. Then there is getting the parts ordered from Off Road before the frosty ground is gone!!
Serial #11K05251 I’ll get the engine serial # tomorrow I think it’s on the left side in the back.
I am tempted to try K&W Nanotechnology Permanent Head Gasket & Block Repair.
I would like to use this machine ASAP but stuff like this can… maybe weld shut partly plugged old expensive radiators and not fix the problem.
Any suggestions on tests or things to service while digging deeper are most welcome!
