Shimmy1
Muffler is cracked up, Cat is VERY proud of it ($2700), I pulled it off to fix, and since the pipe was off the turbo I decided to give it a peek.So what's wrong with the engine? Why you take it apart?
It was an auction purchase,
Wouldn't there be telltale scuff marks from the turbine making contact with the housing?My WAG looks like they ran it with a plugged air filter and that took out the thrust washer.
Any way it needs a new one.
Bob
This is why I posted it on here. My other tractor had the turbo replaced before we got it at 6000 hours. I personally don't believe that it was caused by dirt ingestion, the intake piping would be filthy, unfortunately we've been down that road twice with other engines so I know what that looks like. What I've been hoping is that someone would have seen or experienced similar damage to a turbine end and had an answer that didn't involve debris or dirt.#1 It lost a turbo before and crap went through the system #2 High exhaust temps but I doubt it #3 Turbo was defective from the start, that does happen. #4 extremely
hard carbon deposits built up in exhaust manifold broke loose and I doubt that also. #4 it's your unlucky day.
The point of this entire thread is that the turbo should be replaced.
A pugged filter don't mean it will pass dirt but when it is changed the turbo shaft will go back towards center.This is why I posted it on here. My other tractor had the turbo replaced before we got it at 6000 hours. I personally don't believe that it was caused by dirt ingestion, the intake piping would be filthy, unfortunately we've been down that road twice with other engines so I know what that looks like. What I've been hoping is that someone would have seen or experienced similar damage to a turbine end and had an answer that didn't involve debris or dirt.
