what causes a starter to shatter?
Discussion in 'Forklifts/Telehandlers' started by skata, Apr 9, 2019.
  1. skata
    skata Senior Member
    May 10, 2007
    695
    midwest
    a jcb forklift with a perkins 1004 engine. went to crank it up, and heard an explosion! it did not sound good. fortunately i was able to get all the pieces out of the bellhousing. this is the second time this has happened. last time was about 10 years ago. why does this happen?
  2. hvy 1ton
    hvy 1ton Senior Member
    Jul 24, 2006
    1,663
    Lawrence, KS
    The kickout? is out of adjustment and the pinion gear was slamming into the nose cone.
    DMiller likes this.
  3. skata
    skata Senior Member
    May 10, 2007
    695
    midwest
    shouldnt that have been good when i bought it new?
  4. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    2,223
    Oklahoma
    Make sure it is the right starter for that engine application .
    Tinkerer, mg2361 and DMiller like this.
  5. DMiller
    DMiller Senior Member
    Feb 22, 2010
    7,386
    Retired
    Start looking for something else broken allowing that to get side loaded, bell, flywheel bolting, ring gear shifted or someone failed to get fully on, something in there NOT right. Looks to be a Lucas?
  6. skata
    skata Senior Member
    May 10, 2007
    695
    midwest
    This starter has probably been cycled a thousand times at least. Hard to imagine something not lined up.
    I'm not sure who the oem maker is. But i think this starter is widely used among other brands.
  7. DMiller
    Feb 22, 2010
    7,386
    Retired
    Does not change my first instinct. Starters do not just break apart randomly. If is a Lucas(Perkins was as was Allis a defined User) there should be a Delco replacement available, that will have a Cast Iron/steel nose instead of aluminum.
    funwithfuel likes this.
  8. hvy 1ton
    Jul 24, 2006
    1,663
    Lawrence, KS
    It should have been, but it sure looks like the the pinion and nose cone have been making contact. Like Dmiller said, those nose cones don't shatter for no reason.
    DMiller likes this.
  9. TD24
    TD24 Well-Known Member
    Jan 4, 2011
    197
    RETIRED (Mostly)
    MS
    Last rebuilder put wrong pinion on it. Used to happen often on Delco's in Clark forklifts.
    Vetech63 and DMiller like this.
  10. RZucker
    RZucker Senior Member
    Jul 7, 2013
    4,102
    Mechanic/welder
    Wherever I end up
    Looks Lucas or Prestolite to me... Lucas the prince of darkness. :D Used to deal with them on Ford tractors. Hated them. Even the Nippondensos on John Deere tractors were more reliable.
    DMiller likes this.
  11. hosspuller
    hosspuller Senior Member
    Aug 28, 2014
    1,065
    North Carolina
    Picture allows high magnification. Looks like the pinion gear teeth are worn unevenly. (natural for a starter) I surmise the wear allows the pinion to climb on the teeth of the flywheel forcing the nosecone apart, Instead of engaging the flywheel teeth. Check if the pinion shaft is bent or loose. Would not take much movement to break the cast nose. Wear would explain the time between failures.
    Pixie and DMiller like this.
  12. rondig
    rondig Senior Member
    Jul 24, 2013
    487
    excavation
    fort macleod alberta
    Mmmm i have seen this before...when my guys double start machine....or try starting when already running...
    DMiller likes this.
  13. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    2,882
    Mechanic
    Will county Illinois
    I'm not seeing the pinion wear mentioned. I wonder if the hydraulics loaded up, that should have just slowed cranking rpm. But if the casting were porous, well any weak link, will lead to failure.
    DMiller likes this.
  14. hosspuller
    Aug 28, 2014
    1,065
    North Carolina
    Click on Skata's second picture. Even looks like a tooth is broken off. (at the very bottom of the pinion pic)
    DMiller likes this.
  15. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    3,544
    s/e Heavy equipment operator
    Western Washington
    Tooth is still there. it's just the angle of the pic makes it look like extra distance between the teeth along with the relief cut.
    Most of the time I see the nose cones busted off was from machines that had the starter repeatedly engaged with the motor running.
    DMiller likes this.
  16. funwithfuel
    Mar 7, 2017
    2,882
    Mechanic
    Just peeked again, I only see machined lead in cuts. But I'm old and eyes are shot.
    DMiller, mg2361 and kshansen like this.
  17. skata
    skata Senior Member
    May 10, 2007
    695
    midwest
    the gear teeth ends are machined like that. no wear. also, the ignition key doesnt allow you to re-engage the starter unless you turn the key to off.
    DMiller likes this.
  18. hvy 1ton
    Jul 24, 2006
    1,663
    Lawrence, KS
    Maybe I'm crazy, but that looks like contact to me.
    This looks like a burr developing on the shoulder and there is shiny metal at the toe.
  19. TD24
    Jan 4, 2011
    197
    RETIRED (Mostly)
    MS
    Agree with Skata... Brings up a thought.
    Many machines are OEM wired so ign key will not fire the starter if engine is running and there is charging system output.
    This function is dependent on the ign switch being OEM or equivalent and properly wired.
    My question? Has the ign switch been replaced with an non compatible aftermarket?
    DMiller likes this.
  20. Ronsii
    Jun 26, 2011
    3,544
    Western Washington
    My hyster forklift also has a mechanical interlock that will only one turn to crank without going all the way back to off to reset it.
    DMiller likes this.
