What Attachments Do You Use?
Steve Frazier
Founder
Staff member
LaGrangeville, N.Y.
I thought it might be interesting to see what attachments everyone runs, and discover which are most popular.
I've got a Cat 248 skid steer and use the following:
4 way bucket
Pallet forks
Jib Boom
Bradco Backhoe
Harley Power Rake
Erskine High Flow Snowblower
Wish list:
Trencher
Hydraulic Hammer
Auger
6 way Dozer Blade
Taylortractornu
Charter Member
Iuka, Mississippi
Privvate landfill operator/manager
I have 2 older Ford back hoes. One is bare for now, its not been attacked yet. On my 3550 Ford hoe I have a thumb I built myself which I cant live without. A set of home built bucket forks I made. Also a manbasket that will attach to the bucket like my forks. Also a short jib boom for the same fork hooks.
Im planning on building or buying an auger for the hoe, If I cant find one for my machine ill build a 4 in 1 bucket for the front. i also want to build a Laydown box for laying asphaults with my dump truck. I have to build alot of things for my equipment since no current attachents are made for my machinery and to make sure my i use my machinist schooling lol.
dozerman
Charter Member
Friday Harbor, WA
Owner operator excavation
My carrier is an EC-55 excavator, the attachment of choice is the Promac brush cutter http://www.demining.bc.ca/brushcutter.htm. Using this machine it will cut/grind up to 5"diameter trees. It will often lead to other jobs. My other favorite is a BTI rock hammer. We have a lot of that around here. The hammer is harder on the carrier, but fun to run.
....Brad
mert0714
Charter Member
Eastern IA
We have a powersledge (universal impact technologies) for breaking concrete. A Yukon jack bucket for loading out the bigger pieces and prying. Set of forks (rarely used), an adjustable tooth scarfier, a 7' bucket for snow, and (not sure of the brand) an 8'-6" fixed snow plow. It is 28" high and you can put down force on it like a bucket to really cut off the stuck on stuff. The blade trips like a pickup blade but it weighs like 1500#. I call it the man's snow blade.
mpalums
Charter Member
colorado
teacher / home builder
compatible attatchments?
Will cat skid loaders accept attatchments from other brands?
Steve Frazier
Founder
Staff member
LaGrangeville, N.Y.
Most manufacturers use the industry standard mounting system now, so most attachments are interchangeable between brands. I've run into cases where there are different hydraulic fittings used, I know Case is different than Cat, New holland is the same as Cat.
Attachments that require special bracketry or wiring, such as my backhoe and snowblower, aren't readily interchangeable, but if the proper bracket or harness for another machine is aquired, they are.
Not a simple answer, but most non-powered attachments can be swapped, while those requiring hydraulic power will bear some investigation. Another item to consider is whether the machine will meet the hydraulic requirements of the attachment you're looking at.
mpalums
Charter Member
colorado
Cat or Bobcat ???
We are just getting ready to purchase a skid steer and I'm looking for information on the pro''s and con's of these two brands. Obviously you can't put a lot stock in the sales guy pitch because they want you to buy thier brand. It looks like several guys on this site have experience with both and I would appreciate any information that may help my decision.
My Dad has operated a Cat 416 forever and he swears there is nothing better so we are probably leaning in that direction however any information would be greatly appreciated! Thanks.
mert0714
Charter Member
Eastern IA
We are updating also from Mustang. We are going with the Cat (262) because of a lot of different reasons just to fit our needs. I have heard from many that pilot controls will be the thing of the future. It will take a bit to get used to but it is nice. 3 yr warrant is good thing but probably won't need it anyway. I never have investigated Bobcat but have not heard anything but good about Cat from several current users.
As far as your earlier post on attachments, the only thing I have to add to Steve's is that our dealer we are working with said that if you needed to rent an attachment with the added electrical lead, they can fit the machine temporarily with the needed equipment and don't need to have it permanately. Volume of flow and psi requirements are the only other things to watch closely. May need a pressure reducer in some cases other wise mount-ups should be the same.
Blademan
Charter Member
Calgary
Operating Engineer
Mert0714 ,
have a buddy that broke both the arms on his Cat246 . It was just out of warranty , but the local Cat dealer was really good with him , and bumped him up to a 262 for a really good deal . hate to say it , but I've seen quite a bit of new machinery in the last couple of years go down , and warranties are a God send as replacing or repairing costs can quickly spiral out of this world . And as for pilot controls , LOVE them . Faster and way more precise/control . And when tolerances are VERY thin , it makes a world of difference .
Rob
mert0714
Charter Member
Eastern IA
Glad to hear that the dealer helped out on that deal. What in world caused that to happen? I have heard of stress cracks in early experimental models but broke? Run into something to hard or too much weight? Where did it break?
I know the warranty is a good thing, but the company essentually is betting that their equipment is good enough to stand through the period with no probs. Sure can help with sleep at night.:)
mpalums
Charter Member
colorado
Cat Skid Steer Warranty?
What is the standard warranty duration for Cat skid steers? Does it work like auto warranties where it is still in effect even if you buy used?
paulsoccodato
Charter Member
yonkers, new york
contractor
for my ls170 skid, i have
66" low profile bucket
72" low profile bucket
66" dirt & foundry bucket w/ teeth
pallet forks
bradco 609 backoe w/ thumb
loegering tracks
next year i hope to accuire a harley rake for it.
for my ec-55 excavator, i only have a 2' gp bucket, with a 40" grading bucket on order.
i also hope to buy a hammer for it next year.
riggler
bristol, ct.
self employed contractor
hi guys, steve here . at the moment i have a 2 scat tracks a 1500 high flow, and a 1750 high flow. current list of attachments include: a 66" and a 73" 4 in one buckets
66 " light material bucket
73" foundry bucket
73" dirt bucket
73" bolt on tooth bar
8` fisher snow plow (custom built it moves 6 ways)
kent demo hammer
2000 8' power angle harley rake
2003 66" rockhound power rake
2 sets pallet forks 42" and 48" tines
Mc millen 3650 high flow auger
42",36", 30",24" 16", 10" pengo bits
major 73 " sweeper with curb brush and water tank
mc millen .5 yrd. concrete bucket
loegering over the tire tracks
custom built "pigs prick" rigging boom
cat320
Charter Member
Stoneham,MA
A question for skidsteer attachments. When you figure a job with a machine and most of the job is with a bucket what do you or how do you charge for the attachement like say a stump grinder? If the grinder cost $200 a day do you charge the extra $200 or add more on or even double the daily charge?
Steve Frazier
Founder
Staff member
LaGrangeville, N.Y.
I price my attachments according to their value. My backhoe cost $13,000 so I have to recoup some of that in the rental price. I send my machine out with bucket and forks at standard rate, anything else raises the rate.
My snowblower was a substantial investment and can only be used 3 months of the year, so there's a premium attached to it too.
2004F550
Charter Member
Connecticut
Operator/Student
Mustang 2040 w/ enclosed cab
-60" dirt bucket
-Pallet Forks
-66" Grapple Bucket
-78" Fisher snow plow
-66" snow bucket
-60" Rock Hound landscape rake
-72" Sweepster Broom
-Tree scoop
Wish for....
- Snowblower
- And a mini excavator
puredieselpower
Allen, Md
I build Pole Buildings
t-180 bobcat
I use my
74" bucket
pole claw
auger 18" bit
pallet forks
and my custom boom
wish list
How to decide there are so many attachments like to have them all
on edit: have to say my favorite is the pole claw can grab up to a
45' and rotate it i use it to set my 8x8 on pole sheds.
CascadeScaper
Lynnwood, WA
2nd year Operating Engineer Apprentice
Cat 216
-60" Cat combo bucket
-Forks
-Harley M6 Rake
-Cat T9B trencher
Cat 277B
-Skid Steer Solutions 85" extreme duty root grapple
-78" Cat combo bucket
CGSI
Claverack, NY
NH LX565
66" GP Bucket
72" HD Bucket
72" Extreme Duty Grapple
M6H Harley Rake
10' Snow Pusher
Tracks
Still want a backhoe and a few other toys
cat320
Charter Member
Stoneham,MA
I have a question what is the difference between the rockhound and the harly rake? why would you get one over the other or do they both do the dame basic job?
I know this was asked but but if you where todo for hire services what would be a good first attachement for the machine?
