mbavers
Chevy k3500 (actually a military M1008 CUCV 1 1/4 ton pickup). Backing plate bolts came loose, plate eventually twisted the flange that it bolts to and distorted the bolt holes. I bought a used backing plate in good condition.
What I plan to do: Heat and straighten flange as well as I can. Test straightness by installing backing plate and drum and testing by measuring drum-plate clearance all around. When I am convinced of evenness, tack weld new backing plate to flange gradually all around to avoid over heating and distorting plate. Test again. If still true, continue welding. I do not have the equipment or wherewithal to replace the flange, so this will have to do. Truck is only used for plowing a private road and max speed is about 10mph, so superior braking is not an issue. Opinions and advice welcome, but please don't tell me to replace the flange.
