Water blows out radiator immediately when started on D5
Discussion in 'Dozers' started by Missouri Darrell, Jan 23, 2022.
  1. Missouri Darrell
    Missouri Darrell New Member
    Jan 23, 2022
    1
    Missouri
    I have an older D5 bulldozer. Before starting the dozer, I check the water in the radiator. It is full, I leave the cap off, start the doZer and it immediately blows the water out the top of the radiator, bad.....Why. Dozer has a new headgasket and a new water pump. Problem has not been fixed..
  2. Tyler d4c
    Tyler d4c Senior Member
    Mar 2, 2016
    1,039
    Salix Pa
    Is the water pump just pushing the water out due to no thermostat or is it actually getting combustion pressure in it
  3. Delmer
    Delmer Senior Member
    Jan 3, 2013
    7,662
    Was the head pressure tested? head and block checked for flat?
    You could try filling the radiator back up to just above the fins, then starting again, sounds like combustion leak though, sorry.
    kshansen likes this.
  4. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    7,976
    Welcome to HEF, Missouri Darrel !
    What happens if you leave the cap on after filling it and then starting it ?
  5. catman13
    catman13 Senior Member
    Aug 22, 2011
    410
    oregon usa
    head gasket or cracked head, sorry not good news
    56wrench, kshansen and Nige like this.
  6. Dave Neubert
    Dave Neubert Senior Member
    Jul 18, 2018
    1,167
    Monroe NC
    Sounds like a cracked head
  7. heymccall
    heymccall Senior Member
    Feb 19, 2007
    3,920
    White Oak, Pa
    How much water is it pushing out?
    On my D4H, it has no overflow bottle, therefore, it is only filled to the top of the square insert down inside the top tank.
    Could you have it overfilled?
    Tinkerer and Delmer like this.
  8. D5Dan
    D5Dan Well-Known Member
    Sep 29, 2021
    64
    Oxford, Maine
    You mention installing a new head gasket and water pump...any work/rebuilding of the head? And as asked above, any pressure tests? Is this “older” D5 a pre combustion chambered head??
  9. d9gdon
    d9gdon Senior Member
    Feb 12, 2010
    1,446
    central texas
    It's the seals on the pre-combustion chambers and/or pinholes in them caused from cavitation due to previous failure to keep the coolant conditioner additive up to date.
    Buy the tool on Ebay to unscrew the chambers to replace the orings and check the chambers closely for pinholes. Pretty cheap to fix.
