Was using empty oil buckets to drain hydraulic oil and found this.
Discussion in 'Lubrication' started by JTWAT, Feb 25, 2019.
  1. JTWAT
    JTWAT Well-Known Member
    Mar 14, 2012
    117
    Central FLA
    I peeled the lids off of two empty TSC 303 oil buckets and found this crud in the bottom of both of them. Not using that oil anymore. KIMG0480.jpg
  2. Jonas302
    Jonas302 Senior Member
    Jan 4, 2015
    495
    mn
    That why cat pails are black (;
    check and Ronsii like this.
  3. Junkyard
    Junkyard Senior Member
    Jun 5, 2016
    2,812
    Field Mechanic
    Claremore, OK
    And they come with a hairnet! Lol
  4. JTWAT
    Mar 14, 2012
    117
    Central FLA
    lol
  5. Old Doug
    Old Doug Senior Member
    Oct 16, 2013
    1,021
    Mo
    I never liked Pennzoil because the yellow jugs were about clear. I dont know if other oils have as much crud as pennz but you can see it in their jugs.
  6. walkerv
    walkerv Senior Member
    Jan 22, 2016
    637
    wingate nc
    Our pails of mobile oils have some but not that much gear oil is probably the worst hyd is the best looking
  7. John C.
    John C. Senior Member
    Jun 12, 2007
    5,773
    Color is not a gradable characteristic of hydraulic oil.
    The other thought is they were empty buckets and it isn't mentioned where and how they were stored. Did they have vent holes on the lid? Was there water on the lids that could have drained down? Was the original contents poured out or pumped out. Were the buckets used for waste oil on some other project? Since waste oil was going back into them, why did it matter what was in them at this point?
  8. fast_st
    fast_st Senior Member
    Dec 1, 2010
    1,098
    IT systems admin
    Mass
    I've seen more than a few white buckets that end up having a small amount of sediment type stuff in the bottom, you can't feel it but you can see it, must be some kind of processing residue. That's why bucket oil is thought to be 'dirty' according to Nige.
  9. Nige
    Nige Senior Member
    10,591
    Let me re-phrase that. Almost all new oil IS "dirty" (not though to be) in that it does not meet OEM minimum cleanliness standards of ISO 16/13 or better right out of the box. That is irrespective of the jug size from 1 gallon up to 55 gallon, 250-gallon totes, and bulk.
    We came across this just after the Millenium when Contamination Control started to become a buzzword, and the situation has not really changed much since then apart from the fact a lot more people are aware of it. It was surprising at that time how few samples of new oil met OEM standards, or even came close. The manufacturers all indicated they could provide oil that met OEM Cleanliness standards, but at a price - and of course nobody was prepared to pick up the tab for the extra cost. So what most large job sites do is kidney-loop their oils while they're still in the bulk tank to get them to acceptable cleanliness levels before they are dispensed. For example our bulk SAE10W hydraulic oil is generally supplied by the oil company to us at somewhere around ISO 17/14 or 18/15. We kidney-loop it down to at least ISO 14/11 and sometimes to 13/10 or 12/9. From 18/15 to 13/10 is a reduction by a factor of 32 in the amount of particles in the oil. Even 17/14 to 14/11 is a reduction in the particle count by a factor of 8.
  10. JTWAT
    Mar 14, 2012
    117
    Central FLA
    I know of one small synthetic lubricants blender based in Superior Wis. that filters their final lubes to 4 micron before bottling.
  11. Nige
    Nige Senior Member
    10,591
    Any idea what ISO Code they claim for their final product..?
  12. JTWAT
    Mar 14, 2012
    117
    Central FLA
    To my knowledge, no product leaves the plant without going through the filtration process.
    I assume you are referring to the ISO cleanliness code.
    I have inquired with their Tech Dept. and will report back with their answer.
  13. Nige
    Nige Senior Member
    10,591
    Yes, I was referring to the ISO 4406 Cleanliness Code. IMHO it would be somewhat strange if a supplier that was making a sales pitch on the basis of an improved filtration process that resulted in better cleanliness of their product not to include this information in their documentation.
  14. walkerv
    Jan 22, 2016
    637
    wingate nc
    20190326_162636.jpg Here is a good picture of our 80w90 gear oil pails , mind you this is service pro brand so i think you would call it a 3rd party oil
