I hate it too, but sometimes you have no choice! Liquid tape will help - for a while! And the rest is the matter of job securityPower probes are ****. Any tool used in modern diagnostics that promotes piercing wires is a joke.
I know about spoon probes but on cars sometimes to get to a connector you have to disassemble half of the stupid car! And it might be dead lead! So that’s why they pierce wires.Instead of sticking pins in harnesses like a voodoo doll, why not use something like the Cat 7X-1710 Test Probes or the Fluke equivalent..?
They "spoon" slides along the outside of the cable and into any connector until the end touches the pin or socket inside.
I'll post a photo when I find where I put my iPhone cable ...........
Unfortunately with our type of equipment and working in an area that receives somewhere over 4m (160") of rainfall per year on average there are no areas on machine wiring that don't matter. This is especially true of electronic machines that use stabilized ECM-supplied voltage to power sensors and send PWM signals via other wires in the harness. Once dampness gets in you are, in the words of the famous prophet - helically wrapped around an inclined plane. Screwed in other words.I try to limit my piercing to areas where it doesn't matter anyway. Never where water or corrosion could become an issue.
Our issues on mobile equipment also relate to washing it. Any decent shop pressure washes a machine before maintenance work, but how do you keep water out of places where it shouldn't be while you're washing..? Answer, you can't. The best you can do is to waterproof connectors as best as possible to protect the system during the washing process.I made curious observation: around here bulk of wiring problems (mostly excavators) starts around mid spring. When it turns from relatively dry weather to high humidity and higher temperature.
Another observation is two worst areas for wire damage if a cab and pump compartment, cab I think is a worse, especially where wire penetrate floor or the wall. Maybe if cabs was cleaned more often this wouldn’t happen - but this is a piece of construction equipment, so its not get cleaned as often and combination of dust and moisture creates this muck in which everything gets corroded.
Pump department for some reason almost always covered in oil, and oil over time does the number on insulation, most damage occurs right at connectors, even with weather packs. I blame inferior workmanship and design of wiring on mobile equipment compared to industrial wiring which mostly uses heavy jacketed wiring and DIN solenoid connectors and etc.
I’m not sure about vibration but when it comes with better sealing especially at termination points I think industrial type superior.Our issues on mobile equipment also relate to washing it. Any decent shop pressure washes a machine before maintenance work, but how do you keep water out of places where it shouldn't be while you're washing..? Answer, you can't. The best you can do is to waterproof connectors as best as possible to protect the system during the washing process.
I speak under correction here but I don't think that industrial jacketed wiring would hold up under the vibration of a machine installation.
That’s something I very passionate about! When I see people opening up hydraulic system with all the dirt and dust around the area of work and every move knocks sand clay and dirt down to exposed hose ends and ports because they didn’t care to plug those - I have the urge to induce some physical force to that persons soft tissues, to knock some sence from those tissues to the brain!!!Our issues on mobile equipment also relate to washing it. Any decent shop pressure washes a machine before maintenance work, but how do you keep water out of places where it shouldn't be while you're washing..? Answer, you can't. The best you can do is to waterproof connectors as best as possible to protect the system during the washing process.
I don’t work on other brands too much but Cat is pretty good about wiring quality, routing, and quality connectors. I also usually don’t see too many inaccessible connectors so backprobing is usually not a problem unless it’s just in really tight quarters and I’m not shy about making up a breakout test harness to give access
It irritates me greatly to see shoddy wiring repairs and worksmanship, when doing it the right way usually isn’t hard at all and looks and works much better. It is against company policy to pierce probe, too, for the issues mentioned above.
All I can say is that our guys aren't allowed needle probes on site - period.
We've had too many wiring harness faults caused by people poking holes in cable insulation and eventual corrosion, even if they attempted to repair the insulation at the time
Talking about good practices: not long ago bought me a wire ferrules kit and crimpers, got tired of constant pull out, frey out and hanging by the single thread issues on set screw types of connections! So if someone still don’t know about these - look it up!
And two channel scope, in today’s CAN BUS age you got to have it!
Yeah four channel scope for the hydraulics is an overkill! I don’t even want to do so much electrical work, but in today’s age you can’t get around it.I can understand the convenience of testing solenoids with the PP's output. I like the scope for testing solenoids but that would be unrealistic on a man lift (I have not worked on man lifts), so I get that. That is where the extra long leads of a PP could be real useful. I bought the Picoscope 2204A 2 channel and extra long leads, 20:1 attenuator and adapters for my amp clamps ($160 total) instead of the 4 channel automotive ($900). All my research said it would work fine for our application, and so far it has worked great fro me, just be careful of the voltage you are testing (hence the attenuator).
