Been having a problem with my loaders transmission overheating and sometimes not wanting to move.
Sometime the loader will start and go in gear just fine. Sometime after starting the loader and putting it in forward or reverse it wont move. I have to rev the motor and it will move slowly, then it will suddenly start moving fine. I changed all the solenoids thinking they weren't working properly, still the same. I changed the relays around and sometime that will work to get it to move. Sometime if I tap on the relays it will go in gear and move.
But after all of this the transmission will run hot after being used for a little while. Changed the filters, oil, still the same.
Any ideas. Only thing I can maybe think of its the troque converter pump??
