WA 450-3G Transmission problem
Discussion in 'Wheel Loaders' started by -3Doc, Oct 19, 2012.
  1. -3Doc
    -3Doc Well-Known Member
    Jul 29, 2009
    119
    Ticketed HD Mechanic
    British Columbia
    I have a loader in the shop that has troubles in first gear forward and reverse. When shifting from forward to reverse or visa versa, trans is slow to go into gear and slips, if you let off the throttle then back on the trans goes into gear and is good. Pressure gauge shows low pressure until the throttle is let up then put back down and then pressure comes up.
    Oil is also aerated and park brake doesn't work.
    Any ideas??
    I have also changed solenoids around and no diff is noted.
    Thanks!!
  2. Bob/Ont
    Bob/Ont Senior Member
    Sep 19, 2012
    1,605
    Ontario
    I know nothing about your machine so please tell me some thing's.
    How many speeds does the trans have and can it be shifted manually?
    If so can you shift for to rev in other speeds without this problem?
    You mentioned a solenoid, does this trans have any electronic module ?
    Later Bob
