stven
our 100 is pouring oil out of rear main seal so I pulled the engine and I don't see anything out of the norm I was hoping someone might have exp with this and could help me out with some info Thanks Steve
Thank YouIf you saw oil coming out of rear main seal replace it . It doesn’t have to “look” bad to be bad. Check crank for wear ,you may need a speedy sleeve if wear is found.
No Rondig, you're on point! He can see the cam and bearing. the freeze plug must have popped out. It shouldn't be in the bellhousing though, I wouldn't think. Knock a new plug in and move along.Really ok...im out of my league...i just dont know that engine personally at all....every engine i ever saw had a frost plug or cast closed....good luck though i am out of solutions...
