funwithfuel
The ground dependent pump supplies steering pressure should the engine fail and you are on a grade. For safety sake, you have steering. When the machine is moving above 4-5 mph, if the pump has not satisfied the sensor and computer, you will be limited. In other words, it won't allow you to put yourself in danger.
If you had a clutch or brake band failure, it would code for that failure.
