Chris Moto
recently got a new pump installed on L90 loader. cranks but wont start, no smoke. does the timing need adjusting?
Here are some pictures. All lines have been bled
Model/ serial, at least give us which generation. Straight, C,D H? If it's a straight through D look at your overflow valve. See if your building pressure.
All models, verify supply to lift pump.
can you please point out the shut off lever? i have not worked on this before. someone else replaced the pumpIt looks like your shut off lever is in full off position. Did you align the timing Mark's prior to removal?
See the spring between the throttle lever (lower) attached to the shut off lever (upper/short) that spring should not be there. In the cab, should be a black knob or a red t handle pulled out, push it in. Loosen the jamnut in the short lever and pull it all the way forward on the cable. Make sure that it is all the way forward and retighten the cable stop. Now, try and start it.
