Volvo L120D Oil pressure Low!!!!
Ammar_Jo
Jordan-Amman
I changed the oil pressure sensor.
the loader works fine.
But it shows that the oil pressure is low
And it shows up and disappears when I prees the pedal.
Ammar_Jo
Jordan-Amman
I am using 15w40 oil and when the loader engine temp goes above 40° the lamp flashes and says engine oil pressure Low
Someone saying to me that i have to use 20w50 oil
Please help
funwithfuel
Will county Illinois
Mechanic
please see attached. I have no way of knowing parts cost in your part of the world. But I'll Bet, cheaper than an engine.
  • L120D Lube valves.pdf
  • L120D lube description.pdf
funwithfuel
Mechanic
So now that you opened a new thread for the same problem, What was your physical oil pressure at the sensor? Did you ever check it?
