Volvo EW160 2000 hydraulic system X3 problem
Discussion in 'Excavators' started by Josveinjoensen, Jan 16, 2019.
  1. Josveinjoensen
    Josveinjoensen New Member
    Jan 16, 2019
    1
    Faroe Islands
    Hi
    I need diagrams for Volvo EW160 2000, both hydraulics and electrical diagrams.
    I think the problem is in the X3 valve.
    when working with the machine, and using much pressure, engine RPM go down, and can stall the engine.
  2. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    2,877
    Mechanic
    Will county Illinois
    Maybe a little more info might help others to help you. Are you using the slope and rotate function when this happens? Are you even equipped with X3? What functions work properly, which don't? I am not a wheeled excavator specialist, but I will help the best that I can
    uffex and cps like this.
  3. TVA
    TVA Senior Member
    May 14, 2018
    1,732
    USA
    Does it stall the engine with bypass switch on? Does it do it with attachment only or does the same with other functions?
    TVC should prevent engine from stalling.
  4. uffex
    uffex Senior Member
    Jan 23, 2012
    1,553
    Admin
    Lincoln UK
    Good day
    Suggest you check Delta P
    Regards
    Uffex
  5. Milos 123
    Milos 123 Active Member
    Jun 24, 2018
    27
    Montenegro
    Can anyone help me I have same problem did you solved yours ?
    Thanks in advice,
    Milos
  6. uffex
    uffex Senior Member
    Jan 23, 2012
    1,553
    Admin
    Lincoln UK
    Good day Milos
    Do you have a Perkins engine machine ?
