Mother Deuce
I am seeking a little help with the teeth on my machine. A Volvo EW210B. I received some sorely needed GET in the form of dove tail chisels. My book in the machine directs you to just drive the pin through the bottom. I suspect this to be superseded because the pin pictured is not the pin (it does seem to match the ones in the machine) I received. The pin has a head on it that looks vaguely like the head off a pinch bar to keep it from dropping out. It might drive through if you hit it hard enough to break it. The pin has like a little spring leaf on one edge that when the pin seats it opens in the adapter passage and prevents the pin from working out the top. the opposite side has little vertical nylon spacer. I didn't work real hard at this today, however I quickly reached several conclusions. I can't drive it up, the spring leaf prevents that. I can't drive it through seemingly although I didn't put on my Hulk outfit and see if I could break the top flange, it is scored it seems. At this point I am thinking about trotting out the hot wrench and burning the top flange of the tooth and driving it up. That will work however it seems I should be able to pop those pins without going to that extreme. Thanks ~MD~
