Thanks!!Low brake pressure. If the alarm comes on when you apply the brakes, it is accumulator. if on all the time, likely sender or wiring.
Hope this helps.
Thanks again for your help old timer! It appears that the harness at the pressure sensor came adrift!Low brake pressure. If the alarm comes on when you apply the brakes, it is accumulator. if on all the time, likely sender or wiring.
Hope this helps.
